Yes, i just cut a little hood bracing worked goodtx_widebody wrote:but everything else like driveshaft and shifter line up good???
dont be that guyNameless EJ6 wrote:the hell are you guys answering him? This has been covered for the last 3 years. You can find this information in a search.
EDIT: sorry, that was mean. Just got off work and I'm tired.
Modified by Nameless EJ6 at 12:27 PM 12/7/2005
Dont forget to shim the rotator coil for trans to line up perfect.tx_widebody wrote:I was reading that if u use the stock r32 motor and transmission mounts that u can buy the r32 cross member and it will bolt write up, and that there is no need to buy the conversion kit. Is this true and has anyone tried it, and how did it turn out????
thanks
