HaXoRsMoBiLe »
https://forums.nicoclub.com/haxorsmobile-u31313.html
Mon Sep 11, 2006 3:49 pm
Sup all, Im having trouble getting the Timing belt gear off of the crank Ive tried soaking it w/ WD40/Other sprays that knock bolts and such loose, but this gear wont budge.From what i understand it is supposed to slide off. my crank pulley was a bit tough as well but i just used a gear puller for that. I would do the same for this gear but theres not enough clearance behind the gear to fit the puller in there :-/any tips would be appreciated!Thanks in advance -Paul
