RB20 Crank pulley HELP!!!
MATTs14
Car: Red 1995 Nissan 240sx
I was recently involved in an accident and i bent my crank pulley on my rb20. I was wondering if anybody knows where i could get one or if a crank pulley off of another motor would work. I really need you guys help asap. Thanks in advance
nizmo zilvia
Car: 95 240sx w/ S14 SR20 Blacktop
I believe all rbs are interchangeable. If not then rb26s work on it.
Some one correct me if im wrong, but thats just the top of my head.
MATTs14
Ok thanks a lot. I need one soon so this helps a lot.
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
MATTs14 wrote:Ok thanks a lot. I need one soon so this helps a lot.
The RB20 and the RB25 have similar pulleys... however not the same.
The AC belt grove is a different size between the two, and the powersteering pump pulley has different amount of teeth.
I have all 3 pulley's here so I'll take a picture for everyone's reference.
MATTs14
Will a crank pulley off of any other car work such as a 300zx or off a ka24 or sr20?
Coolwhip
Vendor
I don't know, since I have neither in front of me at the moment. But shoot me an email since I have an extra rb20 pulley here.
Carl H
gotta get a 20 pulley.
MATTs14
Ok im gonna go ahead and buy the pulley from RawBrokerage. Thats one of the most helpful sites ive seen in a long time. I highly recommend them for any hard to find parts. Thanks guys for all your help
gawdzilla
Car: none
i think all 3 pulleys are compatible in terms of where the alternator/water pump belt sits. ps is different between rb25 and 26 for sure. don't know about the 20 but it seems others say that is different too.
jdmser
Car: duh
I've been running a 25 pulley on my 20 for a while now. Only thing I had to to is get a three rib belt for the ps.
Carl H
yeah you can run a 25 pulley fo sho...its even a few lbs lighter than the std 20 gear.but no stateside interchangability.
Coolwhip
Vendor
Crank Pulley comparison...http://blog.rawbrokerage.com/2....aspx
albdrift
Car: 92 240Sx Hatch
use an rb26
