90_rb20 »
https://forums.nicoclub.com/90-rb20-u88860.html
Mon Feb 18, 2008 7:28 am
Okay, here goes. Ive read through my search results and all seem to ask the right question but never come up with a definite solution/answer.
Problem 1 (and biggest problem)
Car cranks, runs and idles FINE. Running, its meters out perfectly for a car with a correctly functioning alternator. Just bought an Optima Red Top and it has been installed in car.
I can crank the car in the morning, drive the car all day, and come home and park it. Wake up in the morning and car is dead.
Possible Problems?
Dead Short?Test: Disconnect the negative battery cable and attach a test light to the negative cable. With key out of the ignition, and doors shut, touch the test light the negative post.
Does it light up? If yes, you have a direct short somewhere.Fixes? Have someone hold the test light, go to your fuse bx and begin pulling fuses one at a time, and reinsert them if it does not kill the light. Once you pull a fuse that kills the light, you've found your source of the short. Locate and repair wiring.
Problem with mine is that it does not light up. So its reading that there is no direct short.
Ive checked my fusable links, and all of the connections, thoroughly cleaned them, and all are in "as new condition"
Any other ideas? Ive heard that some people have problems with their rear defrost running the battery dead while the car was off, any help would be great. I have a battery tester, the battery is good as is the alternator. Car also has all new ground wires.
2) Timing was retarded from teh previous owner. (Dont ask why) He completely rebuilt the motor prior to me purchasing it and I believe he was doing it because he believed that it would be better for break in.
What timing are you guys running? Stock? Ive heard some are running and stock and some are coming out a bit. Just want to know what yall are having luck with.
