rblover »
https://forums.nicoclub.com/rblover-u89803.html
Fri Jun 22, 2012 6:04 pm
its normal, the block is iron and any water and air mix will cause rust to form, use nissan blue coolant or honda blue, the blue coolant has much better anti-corrosion properties, so do a few flushes then when you think you got most of the nasty rust out, fill with the blue 50/50, I just rebuilt my rb20 and it was alot better in the block ports than my first rb rebuild, still had light rust but no chunks of rust like the first time.
