rb20 coilpacks to rb25 ignitor pack
sil80turbo
i have a coilpack setup like this...
http://www.boostcruising.com/f...26144
made for an rb20 that i'm trying to install on a s1 rb25. the 2 plugs on the coilpack wiring are different from the rb25 plugs which have one less pin. so what pins need to be changed when wiring the rb25 plugs to this setup?
sil80turbo
or how can i wire up an rb20 igniter pack???
fast_s14
Car: 94 300zx
i did this awhile back. i converted a 20 harness to work on a 25. I had to swap some pins around and change the connector ends. I just studied the pin outs in the FSM and it worked fine when i was done. Anyways check out these links for some help.
Retrofit USDM J30 igniter to RB20/25 (series 1)zerothread?id=116502http://forums.nicoc ... ead/251366
