PROJECTRB240SX »
https://forums.nicoclub.com/projectrb240sx-u7958.html
Fri May 14, 2004 8:22 am
THAT SHOULD BE FINE NOW YOU HAVE TO CHECK THEM AT OPERATING TEMP..... REMEMBER EPOXY EXPANDS AND IF THERE IS A BREAK IN THE COIL IT'LL SHOW WHEN THE EPOXY IS AT FULL EXPANSION (OPERATING TEMP). IF THE COIL TESTS AT INFINATE OR 0 YOU HAVE A BAD COIL..... IT NEEDS TO RETAIN RESISTANCE.
