Coolwhip »
https://forums.nicoclub.com/coolwhip-u13264.html
Thu Jan 10, 2008 11:53 am
the first 2 coils of the Q45 are usable correct. (LOL, don't ask me why the others don't, no one ever says other wise)
Could possibly be a shorted coil that when heated up would short itself out.
When you were testing the car, it most likely wasen't using that coil when heating up because it would short itself out, but once you made the connection striaght, it would constantly short where there was no break and ended up burning up the coil.
double check your harness and make sure nothing is fishy is going on, swap around some coils and see if that one coil heats up again to a point where you realize its damaging itself (not saying wait till it starts making damage). If its a isolated problem on multiple coils on that same cylinder than expect the harness.
Thats just my quick guess as i leave the office so good luck.
