RB20 Cam's Need Advice..ASAP!!
redtop240
Car: 92 240 RB20 Coupe
Hey I have a series 2 RB20 and I know this has been talked about but I really need some tech help, or a shop to give me a hand. I picked up a set of RB26 cams that are in great condition, a set of Greddy Cam gears, and I put them in my RB20. But I am not able to get the car to Idle for more than like a minute, before it stalls out. If I keep on the gas it wont Idle out, but it sucks it's my daily driver. Any help, information, or suggestions would be a lifesaver!!!!! Thank's ahead of time guys!!!!
mott6904
Car: rb20 big turbo big cams s13, 97 kouki, turbo audi a4,turbo busa
Did you search before doing this swap. I think there is a certain model rb26 that has to be used in order to make it work. Plus you have to tune the cams in perfect.
redtop240
i did search and most of the information i found was, not all that helpful. Some people just mentioned they had no problems throwing the RB26 cams in the RB20. But there was not that much technical info. I know the cam gears have to be perfectly timed, but i was just wondering if anyone on here or you know of has done this MOD and had success. I am looking for specs or anything to try to get the timing down, or if they wont work at all, I just will have to take them out.
Eikon
Car: 71 240z, 93 Supra TT
A ton of good info in this thread...
http://www.skylinesaustralia.c...+rb20
DriftingisLame
Car: '91 240sx coupe, rb20det
I believe the reason your cams will not idle with the factory rb20 cam timing is because the lobe separation angle is 3 degrees off what the rb20's was. If you read in that thread I believe there's a chart that shows the factory cam specs for a bunch of different rb motors. Find that and you'll be able to tune them properly. Also I believe SydneyKid has done this a hundred times, and I believe he said a good starting point for cam timing is 4 degrees advanced intake, 3 degrees retarded on the exhaust. Confirm that by reading the thread, but it should be a good starting point.
redtop240
anybody know how i can get ahold of CarlH? Eikon mentioned he is a wiring wiz, but i am not a whiz when it comes to locating a user, so dont laugh.
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Didn't the last guy with the 26 cams in the 20 lose all sorts of low end and made very little up top?
redtop240
My friend has a similar setup with a Rb20 and RB26cams, his car pulls so hard at a decent rpm range. I mean he lost a little low end, but man does it throw you in ur seat. It's just a matter to figure out the specs to get it to idle longer than 1 to 2 mins wo it idling out.
