Bluefire wrote:If the wrong cam caps are used, the cam and cap will grind into each other. I don't think i need to elaborate further on why this is bad for your motor.
As for line boring, this most often results in an enlarged bore. With the mains its fine because you can run oversize bearings. But for cams, there are no bearing and there are no oversized cams. Also you would have to find a machine shop with the proper tooling. If they have to buy new tooling, they'll either turn you down or charge you an arm and a leg. Either way you should call up your local machine shop first, they can probably explain a little better than I can.
The machine shop will grind off anywhere from 0.5-1mm on that mating surface of the cap to the head. Then they will line-bore it, with just barely touching the lower journal. I am having that done on my head as we speak as two of my caps/journals were buggered.
Another way is to weld aluminum onto the journal, then line bore it that way as well.......
