oreofreak »
https://forums.nicoclub.com/oreofreak-u10457.html
Sat Nov 01, 2003 8:57 am
you cannot bore a rb20 no bigger the 82mm. Their several different way to stroke a rb20. To make a rb24 you need a rb26 crank, con rod, and 82mm customs pistons. To make a rb23 need a rb25 crank, and con rod, 82mm customs pistons. The rb20 block has to be machined for a rb26 and rb25 crank. It is a lot easier to use a rb25 that is already bored out to 86mm and a rb26 crank, con rod and pistons. You will then have a stroke rb25 which is a rb26 and no machining is required for crank or the pistons.
