matienZo »
https://forums.nicoclub.com/matienzo-u176928.html
Thu Jan 13, 2011 11:21 pm
Me and a few friends recently swapped in an rb20, and after a constant amount of headaches and solving multiple problems, I'm finally stumped.
Car:90 240sx coupe
Engine: rb20det
Mods: fmic, stock everything, ngk bkr7es-11 spark plugs, walbro fuel pump, open dump pipe
Problem: My car would cut out into boost, so I installed a walbro thinking it was a lackage of fuel compared to stock pump, when I did, it ran sooo rich that it would spool, but not go into boost, then sputter. So I let the car sit there while it snowed the past week, and the battery was dead so I jumped it off and it ran great, went into boost, but I can't tell how much because I don't have a gauge. But then, after about 20 minutes of driving pretty hard on it, I let it idle for about 5 mins and I looked up - it was running alittle hot so I hopped back into drive it to cool it off, and it was doing the exact same sputtering and wouldn't hold idle well. So I reset it again and it drove around just fine, but after about the same time, it went back to sputtering.
Cliffnotes: When ECU is reset, for about 15-20 minutes, it will drive/boost fine, then it will sputter in boost and not hold idle well.
Any ideas? Could it be a bad ECU? Plugs getting too hot after driving?
If you need any more info, just ask. Thanks ahead.
