mello88 »
https://forums.nicoclub.com/mello88-u18450.html
Wed Oct 07, 2009 1:35 pm
How are your coilpacks/plugs? Many RBs have the issue with the packs shorting out at high rpm, sending the arc to the head instead of the plug. Check your plug boots to see if any are cracked. Does it randomly miss at idle?
I don't think the problem is related to your O2 sensor. Reason is at high RPMs the ECU runs in an open loop mode. It ignores the O2 sensor and runs only off it's internal maps and primary sensor input (maf, cas, etc). O2 is really only used at idle and cruise to fine tune the afr for clean burn. Anyway if you really want to test it out, you should measure continuity of the wire from the ECU connector back to the o2 sensor plug. I assume you know how to do this with a DMM, just measure the ohms of the wire from the ecu connector to the o2 plug with the ecu connector unhooked from ecu and the o2 connector unhooked from the o2 sensor....
Always a good idea to go back over the basics, check for boost/vac leaks, check your base timing, check plug electrodes, etc... GL
