dizzywithsunstroke »
https://forums.nicoclub.com/dizzywithsunstroke-u83573.html
Fri May 29, 2009 1:26 pm
so i ordered some ARP head studs before i took the stock ones off. i was surprised to see that the stock ones are actually bolts. the new ones however are studs as im sure you guys know. how would i go about installing the new ones? looks to me that i could just screw them in with some threadlock and use the nuts on the other end to tighten them. is this the right way? also are there any torque specifications? thanks for your help. and to avoid getting flamed, I DID SEARCH, but not much luck.
