RB20 and KADE transmission Sensors?
foulplay
Car: 1992 S13 Fastback
Okay well my dad and I figured it out we think. There are two extra plugs on the KA lower harness that went to the transmission knock sensors, do we cut the extra plugs off? See pics.
Close up of plugs
ThanksDanny
Modified by foulplay at 6:09 PM 3/24/2007
Carl H
#2 on the rb trans is the neutral switch and the #1 is the reverse, just swap them out with the ka ones and call it a day.
foulplay
ok, i got the lower KA harness hooked up to the RB with the exception to the two transmission knock sensor plugs. I see the knock sensors and the plug on the RB motor, it looks like the plug goes to the upper RB harness. If that correct then what should I do with the KA knock sensor plugs on the lower harness?
madcowvert
Carl H wrote:#2 on the rb trans is the neutral switch and the #1 is the reverse, just swap them out with the ka ones and call it a day.
can you do this^^^ on the 25 also?
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
MADcow, i dont know about the Neutral and reverse, but i do know you can use a Z32 speed sensor with a red gear and you should be good to go.
Abdo
Car: S13 RB25DET
