Rb20 ACC valve help
dizzywithsunstroke
Car: 1995 Nissan 240sx w/ RB20DET and 1997 Nissan Hardbody
does anyone know which way the small black shaft goes in the rb20 acc valve. i pulled it apart to clean it and the shaft fell out. help me! just need to know if i have it facing the right way or do i need to turn it around?
Modified by dizzywithsunstroke at 6:41 PM 1/22/2009
dizzywithsunstroke
40 views and no one knows? come on your RB gods out there, help me out!
kumasan616
Wow I didn't know you could pull the spring out of the actuator, where is the retaining piece? My guess is the picture has it in the right orientation.
dizzywithsunstroke
no there was no retaining piece. i tried to put it back together like the orientation in the picture and it wouldn't go all the way together. but when i tried it the other way, the shaft slides freely back and forth, which i don't remember it doing before i took it off. anyone have an extra layin around or want to take theirs off and clean it and check it out for me.
onepuff
The "pin" on the half with the electrical connector did wiggle around pretty freely. The brass shaft stayed in the half with the electrical connector unlike yours and won't come out easy. Hope the pics help.
onepuff
The more i look at yours the more different it looks. Here's the part number on mine. Maybe they are different years or something.
Carl H
use a solenoid off of a ka...same solenoid and plug.
dizzywithsunstroke
yea mine doesn't have that little part number plate on it and no markings other than nissan on it. how sure are you about the ka thing, carl?
dizzywithsunstroke
ive been looking at the one for the sr20 and it looks identical in every way (bolt pattern and everything) anyone know about this?
gawdzilla
Car: none
it kinda looks like you broke the actuator. i've never seen the actuator in multiple pieces like you have it. try using a ka or sr actuator and bolt it on to the aac body. should work fine.
Carl H
the solenoids are identical...i have used both ka and rb interchangeably.just make sure you get the brown plug solenoid as the sohc ka used a different plug.any twincam s chassis solenoid will work for sure.
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
zerothread?id=358823
that is the break down!!!
kumasan616
Can just the solenoid be purchased instead of the whole assembly?
dizzywithsunstroke
thanks so much kuillin. huge help!
