xjon »
https://forums.nicoclub.com/xjon-u1094.html
Fri Mar 19, 2004 7:57 pm
Sorry, Yellow. I was going to change all of that when I got the motor but when I saw that it had new belts, new h20 pump, new silicone around the pump and thermostat housing and also new timing belt, I scored.
I know you can get pumps and belts but why do you need to change the tensioners? Does it wear out and how often do you need to change it?
