Sil240 »
https://forums.nicoclub.com/sil240-u6842.html
Thu Apr 28, 2005 3:41 pm
Do you know why they say they will blow up?Alot of people say that engines will blow, but i have yet to meet or talk to someone who has blown a motor due to a pulley.
The rubber on the crank pulley is for NOISE dampening. The 300zx pulley is very very similar to the RB pulleys and ton's of guys run the pulley and make alot of power with it.
I've seen these crank pulleys and they do not have harmonic dampeners/balancers on them.The only cars that have legitimate harmonic balancers are the old V8's.They have a huge heavy solid ring that must be PRESSED on to the crank and then you bolt the crank pulley on to it.
Almost all motors from about 1980 are internally balanced. So it does not matter what you put on either side of the crank, it could be a lightened pulley or a lightened flywheel.
