Me confused. What does the switching of turbos have to do with stud replacement? How do the water lines even make it into the conversation?Mountain_manC33 wrote:well like i said that is the last thing i want to do.
because i want to change out the turbin from a rb20 turbine to a rb25 turbine at the same time and last time i did that it took 5 hours because of the metal lines.
so thats y i want to see if i can find some good penitrating oil first.
and last thing whats PB Blaster?
thanks, i'll keep that as a last resort.wawazat8402 wrote:I just finished dealing with this. I ended up just pull the head and taking it to the machine shop to ahve them remove them. I also decided to replace all the studs no matter what they looked like.
o sorry to confuse you i just was saying that i wanted to spend a good long weekend on it because when i did the turbin swap in my skyline, it took soo long cuz of the water lines.themadscientist wrote:Me confused. What does the switching of turbos have to do with stud replacement? How do the water lines even make it into the conversation?
As I understand this you have the stock manifold and it is off the engine, am I mistaken? It's a safe bet that the #6 stud will snap when you tighten the nut down. Every RB20 I have had has had that one split. The manifold must be expanding at a greater rate on the rearmost cylinders. It doesn't suprise me looking at the location of the turbo on a cast log manifold. The studs threaded into the head are easy to remove for replacement. New studs, nuts and washers are recommended. The washers will split if you try to reuse them and the nuts probably didn't come off without a fight and have battlescars. Now, the studs in the manifold to receive the turbo are a whole different story. They are going to snap and snap all kinds of nasty if you try to remove them; if they just need some wire brush work and a shot of anti seize consider yourself lucky and leave them in. Get new nuts though.
yeah the guy who i bought the manifold from said that he put it into his skyline and broke a few studs and instead of replacing them, he decided to go from rb10 to rb25. but he was saying to let the car sit for a good week and spray penitrating oil (thats y i asked what is the best kind) then spend a weekend doing it.themadscientist wrote:stud replacement should only take 30 minutes after the manifold is pulled. Unless you have busted studs that need to extracted it's a peice of cake, german chocolate cake with lots of shredded coconut, moist and delic,, Dam, now I'm hungry!
Don't sell it b/c of broken studs. Its not that bad, but its no fun. Especially if its one of the back ones that you have even less space than the front studs.Mountain_manC33 wrote:
but if i do come across broken studs what should i do? cuz if involves a lot more work then i think it does, then i might just sell it.
If something as trivial as a stud extraction scares you just quit. Studs are a piece of cake, it only gets harder from there. What are really hoping to get out of this car. Think about it, be honest with yourself. If you are a little skittish take it down to Kinser and have Steve the Manager walk you through it. I have known him for a decade, he will be happy to help you.Mountain_manC33 wrote:
