RB20 1/4 times
EckOMaN2k
Well i just wanted to see what kinda quarter mile times you people run with your rb20det setups an what mods you have. Also im considering swapping a rb20 with basically stock setup in my s13, what times would i expect to run.... say low 14's?
OpeLok
Mods:
Nismo FPR, 3" test pipe, 3" cat back, M's K&N Intake, 24x12x3 FMIC, HKS SSQV, Silvia Brakes, R33 VLSD, Walbro 255lph on stock boost (10psi)
stock tire size/ stock suspension. I had serious wheel hop issues. Could have probably hit 13.6 w/out the wheel hop the way it was going.
Cooch
Car: white 1993 240sx
Dang is stock boost on an RB20 really 10 psi...arent the engines like ca's and sr's rate there hp at 7psi or am i just backwards on this?
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
it might be 7psi stock but most people have exhaust and no cat so the boost prob goes up from that. Note I'm just grabbing at straws here.
Andrew85cm
Car: 89 240sx with RB20det
I run .8 bar on 93 octane gas. With a stock 240sx exhaust so I don't know if that is it. At 94 octane I ran .83 yummy. .8 bar is about 11.6 psi. That may also be a boost spike from the internally gated turbo that comes stock on RB20s that will spike because of heat. The heat which is caused by the majorly restrictive exhaust. That is just my take on it.~ANDREW~
Slo_240sx
Car: Mean Green LS1 S13. Caged and Backhalfed.
Yellow4g63 wrote:it might be 7psi stock but most people have exhaust and no cat so the boost prob goes up from that. Note I'm just grabbing at straws here.
The amount of boost doesn't matter if you run exhaust and a downpipe. It depends on how much the wastegate is closing, which is why people have boost controllers to set boost. All exhaust will do is help spool time.-Alex
NISMO_RB25
Car: 1992 240SX with RB25DET, 1987 RX-7 TII
My RB25 that hit 8PSI with a stock 240 exhaust and Sidemount Intercooler, now hits 11 with the front mount, gutted cat and Apexi N1 Dual exhaust.
So mods can definitely cause your boost to increase without the addition of a boost controller.
mmatl16
Car: 240sx rb20 swap
its 7psi.if any of u got a front clip, check ur gauge cluster and it has a stock boost gauge that reads 7.also i was at my shop yesterday. (and this place is a nissan only shop) anyways when i told them stock boost was 10psi they laughed at me
Wulfgang
mmatl16 wrote:its 7psi.if any of u got a front clip, check ur gauge cluster and it has a stock boost gauge that reads 7.also i was at my shop yesterday. (and this place is a nissan only shop) anyways when i told them stock boost was 10psi they laughed at me
Laugh back at them. The gauge cluster does not read in psi, it reads in 1/10 bar. 0.7 bar is right below 10 psi.
mmatl16
well my autometer machanical boos gauge is reading 7psi.but i could also be boosting 7 cause ive only got a few bolt ons
Miata Master
Car: 240sx w/ rb25det SOON
your added boost is really a boost spike. Yes there is more boost but it is dangerous uncontrolled. If you shot Nitrous it would jump passed 1 bar in a second and POW. Check your actuator.
Not sure if it is 7 Psi or .7 Bar will check when I get home but anyways, mods will not change natural boost unless something is wrong. If the wastegate is to small or does not open enough you will get boost spikes.
Due to your 3" pipes and such your response is faster than the wastegates ability to release the pressure.
mmatl16
Miata Master wrote:your added boost is really a boost spike. Yes there is more boost but it is dangerous uncontrolled. If you shot Nitrous it would jump passed 1 bar in a second and POW. Check your actuator.
where did u get that?i didnt say anything about boost spike. my car is boosting fine.please explain
Yellow4g63
I have seen this happen too many times to list. Example Stock B13 with Blue Bird swap. Stock exhaust not boost controller it was at 7psi, 3" exhaust no Cat and boost jumped to 10psi. Happend on my DSM too.
