RB Wiring questions (wipers, oem wase controller)
StricNyne
Ok i have a couple of quick questions, first off, when i send my wiring harness out for work unfortunately i could nnot find my wiper plug, now i have one, what do i need to do to wire it up and get it working, i dont care if it uses the stalk or is made to be used via an external switch. i just need wipers. i found a good amount of wiring info for the wiper setup but not for people who have engine swaps :( my second questions is that i am wiring up my haletech and some of it reintergreated back into the oem side of the harness before the patch harness, my question is that for my to intergrate my boost controller i would imagine i would use pin 25 L/Y Wastegate Valve Control Solenoid Valve, to replace the oem wastegate/ boost controller with my own wiring ?
StricNyne
god i hate when i make typos, any advice ? i care more about making my wipers work any way !!!
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Look at my RB25 to S14 wiring guide on RBforums. It includes the wiper wiring since I ended up throwing out my Skyline wiper box and had to use the 240 box. Hopefully it will clear some things up for you.
