RB Upgrading questions.
IowaRB240SX
Car: 1991 Nissan 240sx
Hi everyone. I am new here and this is my second Nissan. My first was a 90 TT 300zx. Now I am working on a 240 I got for $200. I now have about $15,000 in parts waiting to be installed. I stripped the car to the shell and have replaced EVERYTHING minus the doors and the roof. I have an RB25 waiting to go in. I have done several Honda swaps and this is my first attempt at swapping and installing an RB. Anyway, here are my questions:
1)I have upgraded to a T3/T4 Garret turbo and tubular manifold. Walt McKinney told me the stock motor could handle 20 pounds of boost. I am not shooting for that high but you never know. Will the stock injectors keep up at this level? What are good injectors to use? I am running a Nismo FPR and Chip in the ECU.
2)What are the inherent problems with the RB25?
3)What is a good estimate for HP on this setup, say at 15psi?
4)Anything else you can tell me?
wawazat8402
Car: 89 Sil80- RB25DET
As far as injectors, there is a local guy with a flow machine. You can check out his site at http://www.deatschwerks.com .
Joe
1)no the injectors will NOT handle that much boost, i belive safe limit is around the 13-14psi range.
2) no serious issues, while the engine is out id highly reccomend replacing the timing belt, water pump and oil pump with upgraded aftermarket ones.
3) HP estimates go out the window when you dont have a full setup to list, we need to know what kind of fuel managment you are running and what kind of tuner you are dealing with
SillyRB
1) a T3/T4 turbo, that is a very broad statement. That can be 1 of like 20+ different turbos with varying covers, turbine sizes and housings. The amount of boost your motor runs depends on the size of the turbo. for example 20 psi on a SC61 compared to 20 psi in a SC50 is a different ball game.
2) Inherent problems with the RB25's the pistons rings are weak. The stock Turbo is not the best. OEM injectors SUCK and at about a 85-90% duty cycle are good for the MOST of about 315-330 hp.
3) Depending on what size turbo you have 15 ~ psi on a average T3/t4 with a .68 back housing will be good for about Approx 350 rwhp but that will depend on supporting mods and tuning. Rough estimate, need more info on your mods. EMS, Head work, IC, etc.
4) Per Kamis prior post, do the easy **** while motor is out of the car. Such as replace the timing belt, new pumps, get a new tensioner. I mean you said you have $15,000 of mods . Where did you spend this money. This better be a amazing car.
Sil240
Car: Nissan S13 "The One Cam Wonder"
yeah what did you do to it?
IowaRB240SX
Well, where do I start with the mods. I have an M-sport body kit(JDM, not ripoff), VIS vented carbon fiber hood, VIS carbon fiber rear hatch,Carbon Fiber mirrors180 sx taillightsD-1 30mm front fenders, 50mm rear fenders, Lexan hatch window, every bar and arm in the suspension is new drift spec(Mostly TEIN, The only stock susp. parts are the front lower control arms), Brembo brake upgrade front and rear, 18" Racing Hart C5's, Cheap Nankang tires because I don't think they will be lasting long, K-Sport 30 way adjustable coilovers, 8 point cage, Options steering wheel, Quick release hub, Nismo short shifter, a slew of guages, 8 Gallon foam filled fuel cellMSD fuel pump, Stainless brake and fuel lines,Of course the RB25, Clutchmasters 6 puck stage 5 clutch,S13 LSD geared 4.40,Mckinney mounts, shaft, wiring, FMIC, pipingKoyo RadiatorFAL Electric fanHKS SSQ BOVTial wastegate 40mmXS Power turbo manifoldGarret T3/T4 turbo .50 AR intake and .48 AR Ex.(I think I remembered it right)Nismo FPRNismo chipped ECUInvidia exhaustTurbo XS boost controlerOil catch can
On order: New injectors, 440ccGreddy timing beltOil pumpwater pump(per this forum)
And Whatever else I may have forgotten.
IowaRB240SX
Oh yeah, and I live in Iowa so the Cat has been removed. Lucky me.
IowaRB240SX
Oh yeah, a 90mm Q45 TB and MAF. Plus alot of custom Fabrication.
foCk
i'd get an electronic boost controller if i were you
Gold Digger
Car: Current:
2011 Infiniti G25X
Former:
1995 Nissan Skyline GT-R V-Spec Midnight Purple
1990 Nissan Laurel Club S Turbo Two Tone Pearl
IowaRB240SX wrote:Well, where do I start with the mods. I have an M-sport body kit(JDM, not ripoff), VIS vented carbon fiber hood, VIS carbon fiber rear hatch,Carbon Fiber mirrors180 sx taillightsD-1 30mm front fenders, 50mm rear fenders, Lexan hatch window, every bar and arm in the suspension is new drift spec(Mostly TEIN, The only stock susp. parts are the front lower control arms), Brembo brake upgrade front and rear, 18" Racing Hart C5's, Cheap Nankang tires because I don't think they will be lasting long, K-Sport 30 way adjustable coilovers, 8 point cage, Options steering wheel, Quick release hub, Nismo short shifter, a slew of guages, 8 Gallon foam filled fuel cellMSD fuel pump, Stainless brake and fuel lines,Of course the RB25, Clutchmasters 6 puck stage 5 clutch,S13 LSD geared 4.40,Mckinney mounts, shaft, wiring, FMIC, pipingKoyo RadiatorFAL Electric fanHKS SSQ BOVTial wastegate 40mmXS Power turbo manifoldGarret T3/T4 turbo .50 AR intake and .48 AR Ex.(I think I remembered it right)Nismo FPRNismo chipped ECUInvidia exhaustTurbo XS boost controlerOil catch can
Yo dude. I am from Galesburg Illinois, bout an hour south east of D-port off of I74.
I am gonna be back stateside in two weeks, if you need any help with anything, Clinton is an easy drive for me. I would love to see this thing.
P.S. I live in Japan.
IowaRB240SX
WELL, it isn't close to being done. All the parts are here and I am just now starting tp put it back together. I stripped it to the shell. Haven't got much done because I am also working on my Scion XB. I am trying to get the body kit prepped and painted by next weekend for a show.
Gold Digger
Car: Current:
2011 Infiniti G25X
Former:
cool cool, but if you need help with putting anything together on that, let me know. I have a group of people down in Davenport that would love to come help out on a 240. hit me up at my e-mail addy sometime...
[email protected]
