Rb Troubleshooting
Drftwhor
Car: 90 s13
Hey whats up i was wondering if anyone could help me out with some troubleshooting.. Alright i have a RB20 i swapped it into a s13.. got all the stuff for it...so it cranks but it doesnt fire to where it will idle... i just orders a SAFC 2 since i have a z32 maf cus alot of people were telling me that the stock rb ecu doesnt read the maf upgrade.. people also told me to unplug the maf and it should idle.. i tried that but it still is just crankin.. i checked the coilpacks and the fuel pump and there workin... i have no idea what else to check.. all i want to do is hear my car run... ive had my car for about a year now... and its been in project mode for at least 8 months...ive had a couple mechanics look at it and seems like they dont know what to do.. also took it to a tuner shop and they let it sit for almost 2 months with out touchin it(then they ended up gettin robbed) ....but i mean i just wanna get it runnin so i can keep up since everyone in my town is goin turbo now.. haha if you have any idea that might be wrong with it please help me out.. Thanks, Goose
Nick51
Car: 90 240sx
did you check all of the fuel pump plugs
mello88
Car: s13
Everyone telling you about the z32 MAF is right, it will not just plug in and work with a stock ecu. Unplugging it should let the engine start in safe mode though...
You said you checked the coilpacks and the fuel pump? If you're getting spark from all the coilpacks... AND the plugs are all wet with fuel... It's most likely not starting because your timing is out of whack. Get a timing gun and adjust the CAS per the FSM.
Does the ECU report any codes? Also what engine parts did you replace/upgrade before the swap?
nizmo zilvia
Car: 95 240sx w/ S14 SR20 Blacktop
You tried starting it with starter fluid? You cant just start a engine thats been sitting for 12+ years. Same thing happened to me. I had to use starter fluid to get everything going. Let it relearn itself!!! lol.
Drftwhor
Car: 90 s13
iight im gonna go try these out ill post back on the progress.. thanks for the help
Drftwhor
Car: 90 s13
ok so i got it to run for a lil bit by using the starter fluid... but then my turbo started spittin out oil... tried to pull it off.. but its dark so really couldnt get it off.. what the hell could that be.. should i just upgrade my turbo?!?!any suggestion..
FAST-DATSUN
things to check, Fuel pressure,fuel lines hooked-up right (problem in about 70% of the cases) dirty injector will not pass fuel.....wiring for injectors...
Drftwhor
Car: 90 s13
well i got it to start... my problem now is that its spittin out oil from my turbo...anyone have a slighty used stock turbo for sale?
Eikon
Car: 71 240z, 93 Supra TT
I've got a RB20 turbo that's in good shape.. can be yours pretty cheap. email me eikond at gmail.com
nizmo zilvia
Told ya it would work. How much oil is coming out? If alot then most likely the turbo is no good.
Drftwhor
Car: 90 s13
haha i was happy to hear it run...but it was quite a bit.. just like spittin it out and then i took off the cold side to check the fins and they spin freely but like it was just oiled up.. i guess its the seals in it.. but tryin to find one so i can get it out on the weekend
nizmo zilvia
Yea probably seals are no good most likely. Im not a turbo expert but it sounds like it.
Anyways you can pick up a RB20 turbo cheap or I can sell you my RB25 turbo since I'll be upgrading soon.
Drftwhor
Car: 90 s13
how much you sellin it for
nizmo zilvia
Not sure yet. I've only put 50 miles on it or so. I just need to use it so I can bring the car to the shop so I can start my tear down. How soon you need this?
Drftwhor
Car: 90 s13
got a meet on sun the 16th.. so tryin to get it out before then
nizmo zilvia
You barely got your car started and bugs worked out. Do you think it'll be safe to drive? Dont want you to drive and end up calling a tow truck back to your place.
Drftwhor
Car: 90 s13
haha thats why im tryin to get it started.. im not messin with it i just wanna drive it so i can see if there are any bugs and what not.. im gonna put some miles on it before i start foolin with it... but its been sitting just wanna drive it again
uber95
Car: S14
You say east coast of Fl. Where at? I know a guy up in Jax. that is good with swaps and could give you a hand.
Drftwhor
Car: 90 s13
i live about an hour south of jax.. which guy.. cus i know some guys at stage 6.. and that pretty much the only shop i know there.. but there are alot of good guys up in jax
uber95
Car: S14
This guy lives probably in your area, he lives in or near Orange Park. He's not affiliated with a shop (that I know of) just a regular guy with some knowledge. His name is Leo. You can find his contact info here:zer...27941
Drftwhor
Car: 90 s13
ohh yea ive talk to leo a couple times... i got his number. so ill give him a call.. my friend travis d is helping me so im sure he can get it runnin
