rb timing belt? issues
armygsrcivic
Car: 1989 nissan 240sx
ok the other day i was pulling out of the parking lot at work and my car started to make a high squeeling noise and then sputtered, and then sadly died. when i tried to start it back up there was a chattering noise coming from the engine. i tried again and the motor wouldnt turn over.
i pulled the timing belt cover off yesterday after work and saw that the idler pulley snaped off from the bolt! do you think i may have just F***** up my valves? im new to nissans so if theres any way i can tell without ripping the head off please let me know.
mott6904
Car: rb20 big turbo big cams s13, 97 kouki, turbo audi a4,turbo busa
You just trashed your valves. You shouldnt have tried starting it again
armygsrcivic
how much does it cost to get new valves put in?
armygsrcivic
i just got the car back from full-race 3 weeks ago. this is pissing me off.
BoostFab
Car: S13cp, S13fb, S14z
armygsrcivic wrote:how much does it cost to get new valves put in?
it depends on the level of damage; you may have to replace the pistons too. talk to a machine shop for an estimate of the repair cost.
armygsrcivic
thanks
Joe
mott6904 wrote:You just trashed your valves. You shouldnt have tried starting it again
they were bent as soon as the pulley snapped.
sorry man, your gonna need a rebuild. this happened to my friend sean (first RB swap in arizona actually)
armygsrcivic
what would you recommend? just the valves or rebuild from ground up?
Joe
you dont know the extent of the damage till you pull the head.
did full race touch the timing belt at all? i know if the wrong bolt is used on the tensioner it will shear VERY shortly after the car begins driving (within a few weeks)
armygsrcivic
Kamin wrote:you dont know the extent of the damage till you pull the head.
yeah they replaced the water pump and the timing belt.
91240sx rb20det
Car: 1991 240sx Rb20det
ya same thing happened to me when i was pulling out oof a parking lot and the tensioner broke loose, and ya it bent all my intake valves (no exhaust though ) so i just took the head off. i couldn't find any valves anywhere so i just bought a new head for like 300. i ported both heads and just built one to put on my rb, if you need anything short of exhaust valves i have it so just e mail me... [email protected] oh it sucks i know cause it was as soon as my swap was done and running right.
armygsrcivic
91240sx rb20det wrote:ya same thing happened to me when i was pulling out oof a parking lot and the tensioner broke loose, and ya it bent all my intake valves (no exhaust though ) so i just took the head off. i couldn't find any valves anywhere so i just bought a new head for like 300. i ported both heads and just built one to put on my rb, if you need anything short of exhaust valves i have it so just e mail me... [email protected] oh it sucks i know cause it was as soon as my swap was done and running right.
yeah i think it was just my intake valves too cuz thats where my buddy said the chattering was coming from
armygsrcivic
where were you able to find a head from?
91240sx rb20det
the classifieds thread, ya just let me know i'll sell you that ported head for cheap. (thats if you can find intake valves) it'd be great if it was your exhaust only, but ya i hardly doubt that
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
If i was you, i'd be asking full race for a new RB25DET for a new long block right about now. Not posting on these forums. Im more than sure they can afford with those over priced manifolds they make.
HxC_Nismo
Car: '98 Nissan 240SX SE R33 RB26DET
'07 Nissan Titan SE
'05 Toyota Corolla
yea i would deffinitly take it back to full race and they might warranty it if the swap was done recently. that sucks though two of my freinds had the same thing happend to there rb20det and rb25det. sucks that the rb's are interfearance motors, unlike toyota i believe majority of there motors are non-interfearance motors.
ANVIL
Car: RB25DET S13.5
ive had to deal with bending all buy 2 of my valves with a tensioner issue, not cheap to fix, and put a lot of down time on my car. luckily the pistons werent hurt. but definitely go check with full race. id guess your pistons are ok if you were just pulling out of a parking lot. mine died as i was turning from a stoplight.
nick6052
Car: 89 240sx RB20det
Hey, I had to replace a few valves in my head... I had to get another parts head.... I still have the head... it is only missing 2 valves if you are interested in any parts. Just figured i'd try to help (: My e-mail is [email protected] if you want pics or more info. Nick
300Plus
Car: 1995 S14 w/ Rb25det Series II
Its on Full Race, they installed the belt adjusted tension, they must have done something wrong. I wouldn't settle for anything but them paying for all the work and all the parts
neonbomb
Yeah you should be calling up Full Race. Its obvious that the core of the problem came from their work.
Neejay
Any update to this?
