DriftingisLame »
https://forums.nicoclub.com/driftingislame-u25409.html
Tue Oct 24, 2006 6:41 pm
The RB20 t3 or t28 whatever you want to call it is good for 14 psi or less... Do not turn it up higher, it is a ceramic wheel and is known to fly apart at higher boost levels.
I made 219 HP and 200 tq with just a mild tune on the SAFC, and 12 PSI or so.
Boost comes on almost instantly, and spools 14 psi right before 3000. Should spool the same on a KA, give or take a couple hundred RPM.
T3 flanged, Water cooled, yes you'll have to tap for water lines.
