You want the truth? I think when I say we I speak for everyone, but we all bring it to a shop and let them install it for us. Also the parts are wicked hard to find so usually one of us goes to Japan to pick some parts and bring it back to the US. As far as working on it, its pretty hard because these engines are different from the ones we have here. And for it being a daily driver its not all that bad. Sometimes we blow a piston or two ya kno? But its all good. Cheers!!mrfarenhight15 wrote:everyone who has swapped an rb25det in there whip, is it a wicked hard swap? does the transmission match up and everything? do you have to cut the firewall? and is the motor good for a daily driver?
i just got 7,000$, so i want my 240 all sexed up.... tell me what i should do!
Dude I was just being a wise *** man but I am serious that these engines are tough to get parts sometimes. By that I mean it'll take days or even weeks to receive if something happened to it. Where as KAs and SRs you can go to junk yard and pick your part or have it delivered next day from Nissan dealership. If you wanna take a chance and do the swap go ahead. Its no different then any other motor just more research needs to be done along with more money.mrfarenhight15 wrote:so i should just go with a sr20det gti-r then........ i seem to get into trouble with fast cars anyway lol.....anyone know how much boost you can push on this motor? my 240 is pretty much gutted, so its wicked light
Ahh probably the same stage as I was at. Don't worry sadly 3 - 4.5g more and it should run.Abdo wrote:i've put 9g in my rb25 swap, so far, and it isn't even running yet..
bahahah!nah, i hope not atleast!i just have to extend a few wires and it should start right up, hopefully.I already got it cranking last weekend, check out my build status post, there's a link in my sig!nizmo zilvia wrote:Ahh probably the same stage as I was at. Don't worry sadly 3 - 4.5g more and it should run.
Coolwhip wrote:$7g's to sex up your 240 is pretty expensive.
But to do so, just grab a can of bearing grease. Lube up your car... lol
this thread = FAIL
that motor is a FWD; are you planning to put it in the 240??mrfarenhight15 wrote:so i should just go with a sr20det gti-r then........
