RB swap questions
skywise
Alright so i have a 91 240sx with a knocking motor. I want to do a rb25det swap into it but im not quite sure how much everythign is going to cost. right now i can buy a rb25 with transmission,ecu,wire harness,cross member,maf sensor,turbo,coil pack,alternator,starter,a/c compressor,power steering pump, intake manifold,exhaust manifold,clutch,flywheel,pressure plate,and throttle body for 2,200. Than i would have to go to mckinney motor sports to get the motor mounts and drive shaft and timing belt. that is going to cost me about 1300.
Now can anyone tell me what else im going to be needing to complete the swap and how much it would cost to do the full swap.
and also i have heard that if you just put the same amount of money into the ka you could get much more hp then the rb stock. can someone please get back to me with this.
OKRB20DET
Car: 1990 S13 coupe
if it comes with a crossmember you don't NEED to go to mckinney just go to a place and get a drive shaft made and save some money
skywise
would that be the only other thing i would have to get to finish the complete swap?
Sil240
Car: Nissan S13 "The One Cam Wonder"
Check out the STICKIES!!!!!!!
