Have you watched this clip?http://youtube.com/watch?v=kRU7HSMXfU8dillards1234 wrote:which would you guys recommend for a rb swap. TopHat,McKinney,or Syko im thinking about the RB25det or RB26dett swap most likely RB25det because it quicker and less work
s14_sport wrote:SYKO Mounts FTW
not necessarily, the r33 crossmember can be had from companies such as jhot imports and other importers. just have to call them and they have, on average, around 5-10 units in stockdillards1234 wrote:dont Syko's require a front clip for the rb mounts and crossmember???
What driveshaft did you use?RaceBredHardbody wrote:I've done 3 RB swaps 1 25, and 2 20's into 3 S13's recently, , and helped with another 20 into a S13 all using the Ruckus Racing mounts, with Megan Racing Isolators ( major plus, uses the stock isolators ), hands down, the best mount kit I have ever used for the money, metal is thicker than Top Hats, alot, the lowers remond me of McKinneys, nice and strong, real thick too. I say Ruckus.
Ditto. Very heavy duty and im using stock Nismo isolators. Everyone overreacts on mounts. All you need to do is relocate your isolators and compensate for the increased loads of our new drivetrains. Only other thing I would do is custom mounts, but who has the time for that.RaceBredHardbody wrote:I've done 3 RB swaps 1 25, and 2 20's into 3 S13's recently, , and helped with another 20 into a S13 all using the Ruckus Racing mounts, with Megan Racing Isolators ( major plus, uses the stock isolators ), hands down, the best mount kit I have ever used for the money, metal is thicker than Top Hats, alot, the lowers remond me of McKinneys, nice and strong, real thick too. I say Ruckus.
