well i tried emailing mack and his respond was kinda weird, but i think he thought i wanted a auto rb swap. he sounded confused. i will have to call to make sure he understands exactly what my question is.Joe wrote:try calling and ask
mack and the rest of the guys at mckinney are top notch people.
sweet that is what im hoping. jw do you know this from personal experience or knew someone who did a rb swap into a auto 240sx? thanks for responsesnyc240sx wrote:same thing as a manual car all u gotta do is get that clutch pedal in with the master cylinder and then get the clutch line to hook up to the slave...get the mckinney mounts and the motorset and drop it in very simple just take ur time
that is exactly what I meant ....thanks for the infogawdzilla wrote:Mack... i think he's talking about a chassis which was originally an automatic, not swapping in an RB and using an RB automatic transmission.
if your question was to swap into a car that had a KA automatic transmission in it, and you are switching to an RB manual transmission, there is no special work required. crossmember, subframe, are all the same. It's the same as if you had a manual car to start.
you just need to add the extra pedal and do the "Park" wiring for the start switch. that's it
