RB swap In s13
Drftwhor
Car: 90 s13
Hey Im dropping in my rb in my s13 but its not fittin on the driveshaft properly. so its restricting the engine from sitting on the mounts. does anyone know anything about why this is happeneing?
Joe
ummm what kind of rb?
Drftwhor
Car: 90 s13
rb20
Vkoslak
Car: 1992 240SX SE rb26dett, 2004 Subaru Forester
Was the car an automatic and you're putting in a 5 speed?
Drftwhor
Car: 90 s13
nah it was a 5speed and im puttin a 5speed back in it..
Joe
unbolt the center carrier of the driveshaft
install the engine/trans
then wiggle the driveshaft into the transmission.
Drftwhor
Car: 90 s13
iight ill give that a try.. if i have anymore problems ill let you know
DriftingisLame
Car: '91 240sx coupe, rb20det
Did you either trim the dust sheild on the transmission, or remove it?
BoostFab
Car: S13cp, S13fb, S14z
Drftwhor wrote:Hey Im dropping in my rb in my s13 but its not fittin on the driveshaft properly. so its restricting the engine from sitting on the mounts. does anyone know anything about why this is happeneing?
either trim or remove this yellow dust cover
Chaos the Xile
Car: 1974 Datsun 260Z
when I did my RB20 i removed it! thats should be the problem.
Drftwhor
Car: 90 s13
the trim is off it wasnt on when i bought it.. but its being a pain in the *** to slide on the driveshaft is the only problem ive got to.
would anyone know where i could get some in piping or did they get it custom?
rotorimp
Car: 02 Xterra, 60 IH Metro
Are you trying to put the driveshaft in at the same time your setting the engine on the mounts? Try setting the motor and then slip in the drive shaft. What mounts are you using/where did you get the drive shaft? the mounts will determine what is available for piping.
kweb
Car: 240sx guitar
Check if theres any rust built up on the splines in the transmission. I had that problem with my d21 and cleaned it with a wire brush and lubed it, slid rite in, could posibly be the problem.
