RB speedometer
2fast4j00
Car: cars, clubs, chix, computers
I'm currently building a 240sx with a rb26dett motor. Is there any custom speedometers I could get to work with this motor? Or is there a way I could at least get the original one to work for a little while until I find a digital one or something?
Brian
Joe
you can use the skyline cluster or the 240 cluster if you plug the KA speed sensor into the transmission
the SOHC KA sensor WILL NOT WORK only the DOHC's
-HyJynX-
Car: CArs...cars..
http://www.gtr.co.nz/ go to interior then gauges, and there are a few clusters here. only thing is there located in new zeland and not sure if they **** to US..
SHIFT_Lock
Car: kouki s14
Kamin wrote:you can use the skyline cluster or the 240 cluster if you plug the KA speed sensor into the transmission
hows that so?
if a single cam will work on a s14 transmission and a s14 will work on a 25 transmission? i've done this. then why wouldn't a sohc sensor work on a 25 transmission.
and i have a sohc sensor on my rb20 transmission.
Joe
well 2 people i have talked to say the speed sensor dosent work from the sohc
i guess im wrong, not the first time
my bad.
HotWIRED
How did you guys swap the sensors? The RB25 is longer then the KA. Did you just swap the speedo pinion??
