Kisorperformance wrote:
ok, hello??? are we missing the point i'm trying to make here.....
DO YOU KNOW FOR A FACT THAT THIS ENGINE HAS STOCK INJECTORS?????
ok maybe now it's a little more clear.
for whatever reason this thing had additional tuning. ie: the stolen AFC. yes fix the f'd up wiring first, if you still have a problem..... you may need to aquire either stock parts....... or tuning equipment of some fashon
hard headed argumentative people..
listen here noob. an AFC is ALWAYS 100% WORTHLESS ON MOST ENGINES.
its a ****ing garbage bandaid to a REAL standalone. when you change your airflow values to trick your computer to add more/less fuel you ALSO change your ignition maps which can wreak HAVOK on your engine and cause nothing but problems
AFC'S ARE s*** AND SHOULD NEVER BE USED
regardless, 95% of people who put them on have absolutely NO need for them even if they do have upgraded injectors.
the odds of him having bigger injectors anyway is slim to none.
