240sxTurbo »
https://forums.nicoclub.com/240sxturbo-u1054.html
Wed Sep 11, 2002 8:07 am
***not intended as a personal attack on anyone****
<rant mode on>
can't blame the owner when the tuning wasn't correct for the situation.
I personally find it hard to believe the RB25 is any weaker than any other RB. The only factor that lends itself to the belief the RB25 might be any bit weaker is its 9:1 compression. That merely means it more likely to want to detonate before say a RB20. The key to fighting detonation is tuning and running the proper gas and keeping those AF ratio's in check, no detonation means good power and safe motor.
We have plenty of KA24DET turbo cars here in the US running 9:5:1 stock compression, stock bottomend, running on JWT setup with 50lb injectors, FMIC, fuel pump, and cobra MAF and they are running 15psi and makine 350RWHP. There is no reason why the 2.5L RB shouldn't be similar in nature, the KA I can promise has much weaker factory pistons than the RB does, yet we manage to keep them together on this side of the pond so what gives.
I"m not saying anything bad about the RB's, just that it seems a lot of the AUS web boards I read there is a lot of skeptics on the RB25, when in reality the only thing that proves true in most cases is, with proper tuning a meltdown could of been prevented. Are they scared to tune em up, or what, seems like they are.......inexpirience??? what gives??
Sorry to rant, but I for surely hope to prove all this RB25 stuff just a myth when I start tuning on mine with a T4, 50 or 72lb injectors and a ECU tune. I will break 400WHP on the stock Head gasket and stock bottom, maybe more, cause I know for a fact that motor is a helluva lot stronger than a KA, and those guys are getting dam close to 400WHP on stock internals.....on a 4 cylinder.
<rant mode off>
thats all.......
