rb/safc settings anyone
fadeds14
Car: faded
ok i searched but cant seem to find any setting threads i got some of the settings but cant find the sensor type for rb that would be great help and if the graph display settings matter any help would be greatly appreciated
fadeds14
Car: faded
no body has a safc in there rb
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
It's HW4 for all Skylines cept the Rb26 thats a HW3. I forget how you set the numbers. 2in 2out? or was 4in 4out. I haven't messed with a AFC in about 1 and half years. :confused: Emange is easy to setup tho :D
Yellow4g63
Kamin wrote:you need to have it tuned. do not rely on other peoples settings.
Yes so true not all cars are the same. What might work good on his might not work good on yours.
goofynick6
Car: 1995 S14.5 RB20DET
I'm going emanage, so I can select "z32 maf" and type in "550cc" injetors..haha. Can't wait.
Nick
fadeds14
Car: faded
yea i was thinking of microtec
HybridOne
Car: swaps
i have an SAFC2 on my RB...what settings are you looking for? Apexi lists the RB20DET in it's wiring instruction manual. So all the information for inital set up is in there. As far as fuel tuning goes...you'll have to get on a Dyno. I actually had to lean my motor out across the board at high throttle. i was running rich as hell. I got about 15 to 20whp by using the SAFC to tune my fuel system.
Also, the SAFC2 will allow you to use a Z32 maf, or any other maf you want. You just have to tell it that your using it. It requires a simple change in the settings menu. It also has a fucnction to change fuel settings when the engine RPMS drop dramatically. This allows you to use a BOV without the car stalling.
BTW, apexi's website has all the manuals available for download.
GTR Shop
Car: 180sx RB26 T78, Y31 Gloria VIP + HEAPS of GTRs!
You can choose the 300zx AFM in the S-AFC.
I D I O T is 5 letters if you are radomly tring to tune the AFC.. you MUST (MUST MUST MUST) use a WB O2 setup.
frosted flakes
so i have to get a wideband o2 sensor if i get an apexi s-afc2? how much do they typically run?
Thanks
Tony
frosted flakes
oh yeah i have a autometer a/f gauge will the wideband o2 sensor still work with it?
goofynick6
The wideband sensor is useless w/o a unit to run it. Techedge makes one and so does Innovative with their LM1 unit. They're usually $350-450.
No, you a/f gauge is no good for this setup.
Nick
Yellow4g63
Check out the issue of Import tuners wide band shoot out. Has a whole bunch of them. They tested them with the MOTEC unit and the NTK one.
frosted flakes
well im gunna tune it on a dyno...so do i still need a wideband o2 sensor?
Yellow4g63
frosted flakes wrote:well im gunna tune it on a dyno...so do i still need a wideband o2 sensor?
Nope just use theres. You would need it if you were going to tunwe it yourself. When I had my DSM I tuned the car with a Greddy EGT gauge and the pocket logger... ahh the good old days.
fadeds14
Car: faded
thank you for your info im taking it to dyno very soon my safc is not totaly hokked up untill it goes to dyno but i just wanted to get the setting for the sensors and i finnally found it thank you all for your help
BoostFab
Car: S13cp, S13fb, S14z
getting on a dyno is basically simulating loads on the motor while the car is stationary. you should plug in the wideband o2 to properly tune your motor. IMO, those generic a/f gauge are crap because it doesn't show af ratio accurately.
if you already own a wideband o2, street tuning is another option, it would cut dyno time cost quite a bit.
