rbsileighty »
https://forums.nicoclub.com/rbsileighty-u4927.html
Thu Dec 04, 2003 7:29 pm
I've done some searching for you and this is what I've found so far. Hope it helps:
"To the best of my knowledge it is an AFM/ECU commanded timing retard that causes the flatspot/s.
On the dyno recently my cars timing was observed retarding from 24' total advance back to 15' during a big dip in the power curve (as felt on the road) this was a problem that I'd "had" @ various times in the past however Jim from Croydon AS did an awesome job of retuning my Unichip to overcome the problem completely.
Unfortunately after I fitted the adj exhaust cam gear (4' retard) this flatspot (or flatspots in my case) has returned so although I gained power (in most of the rev range!!!) I have a surging power curve.
This problem (I think???) is cause by the AFM / stock ECU combo. It seems as if it's detecting excessive airflow entering the manifold via the AFM (ie more boost due to mod's etc...) & then it spoils the party by retarding the "on boost" timing, so you loose power & then as the airflow drops back into the acceptable range it advances timing again & bang it's takes off!
It could be a partically stuffed AFM even?, but I've been in more than the odd GTS25t that has done this exact same thing & they couldn't all have partically stuffed AFM's!!!"
I've run across this same remedy a few times, so hopefully it's not much deeper than this description.
