That sounds like a good idea, but would that fit the RB25? I'm thinking that most skyline stroker kits are for the RB26, but I'll search.Carl H wrote:toss a hks rb28 or tomei rb28 kit in there and call it a day.
That's the mm that I was refering to. I'm thinking that overall displacement is determined by piston diameter in some way, but idk.Kamin wrote:CC's (cubic centimeter) dont translate to MM (milimeter). CC is a measure of volume and MM is a measure of distance
the CC's he is talking about is overall displacment (i.e. 2495cc = 2.5l) and the mm is the size of the piston/bore
its determined by bore, stroke and # of cylinders.gr8bryt wrote:That's the mm that I was refering to. I'm thinking that overall displacement is determined by piston diameter in some way, but idk.
Thanks for the links Cubes. I'm assuming the last one is for swapping the RB into a silvia chassis.
That would be great, but unfortunately I don't know anyone with a skyline in their driveway or under their hood. I'm thinking that most bolt ons will deliver the most benefit towards the top end of the power band and only slightly improve on low and midrange. Sure it depends on what parts you choose and their specs.....I'll just do more research so that I can save myself from looking like an idiot. The internet just frustrates me sometimes because there is sooooo much info that it can be overwhelming and tedious looking for something.250sxGTST wrote:if i understand your post you are looking to change the internals of your rb to gain low end and midrange power? talk to anyone with an rb 20 or 25 and ask about power delivery. you dont have to do anything they come with incredible low to midrange power stock. better yet, go drive one, leave your engine alone internally and just put the car together. go buy some big drive tires and an lsd cause you'll need it.
I'm rarely ever satisfied with anything. My output goals are somewhere around 550 whp, I don't think stock will cut it. At the same time, I want a comprehensive build up that is also reliable. I want to have a good all around car whether it be for just cruising around town, getting a few trophies at a show, or laying pipe (stripe) at the track. Of course I could have a well balanced car with less hp, but I guess I'm a little power junkieRBTALLY wrote:just put the stock rb25 in u will be happy with it.
