been having so many headaches with this car, Im at my wits end. I finally got the wiring bugs figured out (i think).. and now its got more problems.
I have a neo rb25det thats starts up and runs super duper rich, stumbles at idle and and doesn't want to rev up. In addition it seems i have a boost leak of some sort because the gauge is reading zero vacuum, and zero boost when I rev it up.
Ive checked:
TPS voltage @ .7 volts with the switch on, cant seem to get it any lower.. should be .4 to .5
MAF voltage is showing .2 volts with switch on, and around 1.7 volts @ 2k rpm which is dead on.
coolant temp sensor voltage is also dead on around 2.7 volts when i tested it after having ran it for a few minutes. (should be 3.5cold, 1.2 hot)
have yet to check o2 sensor.
The car seems to run much much better with the MAF unplugged, but obviously it wont rev past 2500. it idles much better, and I can also hear turbo flutter when i rev it, something i don't hear when i plug it in oddly. as soon as i plug the maf back in it starts taking s*** and goes back to pig rich mode.
now the difficult part is that this is a NEO motor so not many have experience with it. On top of that I adapted a GTR throttle plenum to it, so the vacuum is a little tricky with ITB's. In addition I had to remote mount the IACV..Im gonna go back and double check all that, but taking vacuum out of the picture it should still idle and drive no? I don't understand why it wont hold idle and why its running so rich. I double checked my fuel pressure and its a little high but I cant get it any lower without good vacuum.
Forget that its a NEO motor, i know this is something small that Ive overlooked and probably common to all rb's so don't be afraid to shout out a suggestion. What controls the idle on these things? I haven't tried messing with the IACV yet.
like i said any suggestions would be great.
thanks for reading
