gawdzilla wrote:the main issue with any real "swapped" car (v8rx7, rb 240, etc.) is that the motor is not designed to be in the car. most times it leads to a lot of custom fab or jerry rigging to get things to work, which usually drives up price or hurts reliability.
when you do an SR its more like a basic honda swap. i see it a bit differently because it is basically oem. direct bolt in and everything just "fits" easier. most ppl can spend their budget elsewhere when doing an SR, rather than on getting over the fitment hurdle for a swapped car.
the rb engine itself is not unreliable, but when it gets forced into a car it does not belong in it can be unreliable if not done right. it's easy to overlook the small things that ppl often take for granted on an SR or similar type swap
to elaborate on that a little bit:
that doesnt mean it cant be made reliable. you just have to take your time and spend the money to do it the RIGHT WAY and it will be just as reliable as a stock engine in a stock car.
i am not nice to my car. at all. i had a RB25 in it for about 4 years, solid 2-2.5 of track only use. and it was great. never had a problem with it outside of little issues that come up with all 10 year old cars. new motor, which we can safely say is a bastard because it has a chevy engine, has been more reliable. i literally have not turned 1 wrench on it to fix anything in the 11 months its been in. everyone calls me "lucky" i tell them its because i spend a ****load of money, and time taking care of it and making sure everything was done correctly.
