Rb PowerSteering
HPF Chrisk
Car: 240sx
Hey guys i have a few questions on my rb25 swapped s13. When the motor was first swapped i was using and single cam ps line and it didnt last long because i had to bend it a bunch to work. After it broke i just removed the belt and ran it with no ps. well after about a year i got tired of that and came across the racebread.com ps write up. So i did it exactly like the write up says and ordered the same fittings and line and now the fitting that goes into the pump is just dumping out fluid and i cant figure out why. Its tight and everything. Is anyone else having this issue with this setup?
gawdzilla
Car: none
is it leaking at the fitting? try using a crush washer
HPF Chrisk
Car: 240sx
It is leaking at the fitting and i didnt put a crush washer in there, i believe stock has one right there for let me put one in tonight and see if it fixes the leak
