rb power
nizmoguy
Car: 1995 s14
How many pounds can i push with a stock rb25 series 2 motor?
eh?
I'd reckon you'd be able to push about 4000lbs or so with an S2 RB25 240sx. But I'd think it might be a better idea to install a trailer hitch and pull rather than push.
govtworkhorse
Car: 95 240sx SE, 95 240SX, 91 Festiva (DD), 03 GSX-R 600
eh? wrote:I'd reckon you'd be able to push about 4000lbs or so with an S2 RB25 240sx. But I'd think it might be a better idea to install a trailer hitch and pull rather than push.
StricNyne
well it depends in a urban environment i get roughly 10 pounds per square yard from my homies showing me some dap...
themadscientist
Oh boy, here we go. OP you need to clarify what you need . 14 lbs on a stock turbo and 14lbs on a T51R is not the same thing.
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
Depends which corner you're working. As well as how much you can get through the harbor port.
240wootie
Car: 1989 rb20 coupe, 2002 WRX
themadscientist wrote:Oh boy, here we go. OP you need to clarify what you need . 14 lbs on a stock turbo and 14lbs on a T51R is not the same thing.
14=14 wheres the difference?
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
lol
leesredgt
Car: 1992 Toyota MR2 N/A
1991 Toyota MR2 Turbo
first of all r u talking about a completely stock engine as far as turbo wise?with a stock turbo on my sreries 1, 12 pounds is the max its proably safe to say the same for u. as far as internals all i know is 450-500 is about the max hp you can have. hope that helps.
240wootie
there has to be about a billion (maybe 1,000,000,001?) "how much power can i get out if stock blah blah blah engine/turbo/whatever" threads.. go buy a chevy LS and knock yourself out...
StricNyne
he differance between the 14 psi on dif turbos is CFM do a look up on how things work and turbos
