RB pedals don't work for auto->manual
curbsurfer253
Just wanted to clear up rumors that an S14 auto--->manual swap can be done using R33 skyline brake pedals. This is a definate no. I spent yesterday fighting and trimming the pedal to try to get it to clear the steering colum and its a no go. Just wanted to give you guys a heads up. ;)
JonPowell
Car: Cars, Music, My family
The Japanese brake pedals are on the opposite side of the steering column so they WILL NOT WORK.
You are absolutely right.
Just take your stock brake pedal and trim t down.....then add the clutch stuff.
PROJECTRB240SX
Car: 1972 DATSUN 240Z W/ SR20DET
THE R32 PEDALS WORK FOR THE S13'S.... WE'VE USED THEM TWICE.
JonPowell
I tried S13 Silvia and R33 pedals to no avail. At least there is another alternative.
krayton
brake = no
clutch = yes (of course its longer and takes a little work, but it can. right along with the clutch cylinder)
accordscantdrift
krayton wrote:brake = no
What kinda work? is it easyer to just find a stock clutch petal and clutch cylinder for the s13?
krayton
accordscantdrift wrote:What kinda work? is it easyer to just find a stock clutch petal and clutch cylinder for the s13?
skyline is easy. the s13 i had to make a little spacer for the pedal. i think 1 of the bolts was a little off, so thats where the spacer came in.
also extended the adjustment thing that has the pin? no clue what its called. but a spacer from ace solved it.
the s13 is very close to stock.
