govtworkhorse wrote:The search button can take some abuse, too bad nobody ever puts it to the test...
That is hilarious.
I made it cry yesterday looking for rb20 custom intake manifold write-ups.
Personally, the rb20 wins by the coolness factor and by the fact it has 2 more cylinders. I'm not biased or anything , but to me the engines perform so similar it is all personal preference. Although the the rb20 has 8 more valves, a shorter stroke, 6-cylinder orchestral glory, and is cheaper AT FIRST. The downside is that you inherently buy bigger/more parts (cams, cylinders, rods, valves, springs, coils, studs, blah blah) when upgrading the motor, it will cost you more money.
Drifting entails lots of high revving and long-term heat dissipation. At first the rb20det is not ready for the latter nor is the sr20. Buy a bigger radiator, low temp thermostat, n1 water and oil pump, electric fans, coolant temp gauge, and replace all water hoses. You will also want to rebuild either motors with aftermarket headgasket, and headstuds--(if you do the sr20det you will want the rocker-arm stoppers and if you do the rb20det you will want to do the crank collar modification). My two cents if you really wanted to drift.
Modified by Jesse J at 5:52 PM 1/15/2008
Modified by Jesse J at 5:53 PM 1/15/2008
