RB not getting fuel/fuel pump not kickin on?
SR20DETGUY08
Car: S14 Kouki
Ok I have an RB25 s2 in my 97 s14. I relocated the battery to the trunk. I dont have the maf hooked up yet (thanks to nasty harness/ignorance of wiring smarts) but everything else is hooked up. I installed a walbro fuel pump and when I went to try to start the guy I attempted to prime the pump but never heard it kick on. Ive tried quite a few times to listen for it to click on but nothing. Also, my fuel gauge now reads empty and before I put the walbro in it read fine-at about a little over 1/4 tank. So, I tried to start it anyway but I pulled a plug out and I cant smell any gas on it. Ive checked my grounds and fuses/relays and as far as I can tell everything is good. Im sure this problem has been posted a million times but Ive searched and cant really find good answers.
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
check all your fuses and your wiring to the plugs! 12vdc and grounds
radianation
Car: 1996 Nissan 240sx with built RB25DET
Any chance you reversed the wires on the fuel pump?
GTS-T 240
Car: 1990 RB25DET 240sx
i would check the fuel pump harness i had the clip burn up on mine and some of the wires had burns in them.
SR20DETGUY08
Car: S14 Kouki
no the wires are connected right on the fuel pump. Ill pull it back out and look at it to see if anything went wrong.
WhatsADSM
Car: 1998 240sx
instead of pulling out the pump, why don't you disconnect the harness and check for voltage at the connector? You should see a 12v at the connector when someone cycles the key from off to the "on" position.
It really could be a wiring issue leading to the pump.
SR20DETGUY08
Car: S14 Kouki
ok ill try that first. My buddy thinks its just a problem of grounds but I dont see where that would be the issue. But, Im a noob at wiring. Hopefully well figure it out tomorrow
DriftX
Car: '89 240sx
loost or dirty connections.
That would explain your resistance reading for the fuel tank sender being off and no power..
SR20DETGUY08
Car: S14 Kouki
sorry started another thread...we got fuel going to the car it was becasue the f4 plug wont lock into the connector...ziptied=fixed! now we just cant get it to start...
