RB Motor, Trans, and Sway bar mounts. FEELER.
camracecraft
OK guys, mount kits that require a cross member that is almost impossible to find, REDICULOUS. Mount kits that cost $350 but still have a problem with sway bar clearance, also REDICULOUS.
I have been working on some mounting brackets for my RB20DET swap, and have designed some VERY INEXPENSIVE but STRONG brackets and mounts.
Now this is just a feeler for the intrest in these items. If there is even the slightest intrest i will proceed further and provide all the info and prices. I am currently working on the pictures.
These will be sold in eigther a kit or in pieces for those of you who already have some of the parts. They are the two motor brackets that use the stock KA crossmember, Two brakets that enable you to use the stock KA transmission mount, and Two spacers for the front sway bar. The motor brackets use the stock RB rubber isolators, i am in the process of having some urethane isolators designed.
As everything is coming together, I am confident that i will be able to offer these as a kit that includes the brackets, and all grade 8 hardware for around $140-$160.
These are an experimantal product for the S13 chassis with Rb20DET. please present any qeustions or concerns that you may have.
mello88
Car: s13
Sounds good please update with more info when you can.
Sil240
Car: Nissan S13 "The One Cam Wonder"
Nice!!!!
Syko performance has what your looking for, but.... for a lot more $$$$$
Good work!!
240sxautox
Car: 1993 Nissan 240sx SE
i'm def. interested in the sway bar mounts, i had never heard about them not clearing. I'm putting an Rb20 into an S13.
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Weird I still have my front sway bars with my swap. I have good clearnce from the oil pan too. McKinney mounts here.
Shocker
Car: 89 240sxHB rb26/30
my sway bar rubs on my oil pan, and I have mack mts.
FAST-DATSUN
If your sway bar hits you only have to add a washer or two to get the needed clearance, most do not hit, but ever car is different.
240_jz
I know this thread is old, but I was just wondering if you were still making the sway bar spacers, i emailed you already.
