RB Mod/Power Update Thread
rbsileighty
Car: 92 S13 Hatch w/ RB20 & 05 Audi S4 Avant 6MT
So between everyone selling stuff off and natural progression... what's everyone's stance as of now with their projects?
How about some mod list updates and some power figure statements for everyone if you have them. Let us know how your power band is if you have some serious mods (upgraded turbo/manifolds/EMS etc)... don't forget to include boost pressures. Throw in some updated pics if you have them.
I wish I was making this thread b/c I had just done something, but mine's still in the turbo "on it's way out" state pushing a massive .4 bar. Luckily I picked up a new (to me) RB25 turbo to slap on at the end of Sept when I get back to the vehicle... she'll be on the road again before to long. Pics and mods are in the link in my signature.
So let's have it... what's your status???
sean8564
Car: 1993 Nissan GT-R V-Spec
1991 Nissan 300ZX TT Black
1993 Nissan Silvia
1990 Nissan 240SX Coupe RB25DET
just got the 2nd motor running a week ago so RB25DETWalbro 255 3 inch downpipe no exhaustAftermarket FPR adjustableCusco Super single plate clutch and light FlywheelEverything elseR32 VLSD5 lug Swap R32 Gtst CalipersR32 GTR wheelsthat is all for now
Modified by sean8564 at 3:03 PM 8/16/2005
shedrifts
Car: rb powered sil80
just ordered the last bit of parts for my rb20
gt30r turbo 550 cc injectors z32 mafwalbro 255 fuel pump greddy emanagegreddy eo1 boost controller3" turbo back front mount intercoolercustom intake manifold "diy"turbonetic deltagatemodified turbo manifold to allow use of the deltagate blitz dual chamber blowoff valve hope to have some pics up and soon once i finish with all the powder coating and stuff
Imissmyturbo
Car: Car's, Turbo's, sking
RB25DET swap56 trim turbo15 psiApex Power FC480cc injectorsnismo FPRI guess I am making about 320-350 whp
Future mod is an RB26 swap I have in my garage....still can't figure out if I want to go through with it.
s14 2510's
Car: 96 s14 rb26 2510's fully built, 91 s13 sil truck rb20 in works
rb26/96s14Fuel system: 16 galon cell with foam, areomotive a1000 pump, aremotive pressure regulator, steel braided line with feeds to both sides of the rail and a return, I still need to buy hks rail and 720 RC injectors.
My engine is still beeing worked on. I have je pistons .5mm overbore, carrillo rods, black coated bearings, arp mains/head/girtle bolts, Tomei 1.2mm full steel gaskit kit, knife edged crank, micro polished lower end, He still needs to blueprint/balance it with the giken twin plate then I will be ready to fab an oil pan for my morrosso dry sump, n1 water pump, hks 2510 turbos, Mines mass air sensors and dump pipes, apexi gt spec exhaust, apexi power fc with commander and boost controler, ati dampner, oil cooler/filter relocator, ported/polished/portmatched head with some other work done, giken clutch/TO bearing/fork/pivot/adjustable rod for slave/and a return spring and bracket to pull it back, nismo termistat, koyo rad, flexlite twin fans, rewireing for s14 done, rebuilt starter/impoved alternator, rb25 trans, big greddy front mount, blitz dd, cold side piping done hot side was done but I want to remove the stock pipeing and make a smoother equal length pipe(like the hks kit). I still need to buy cams, springs, retainers, Make a turbo manifold with a balance tube, parts to finish dry sump, 1 piece drive shaft, volk gt-p whells( I almost have enouf $) I need to order them soon as they take soo long to get, The set of toyo's that I want, Tein rs coils, miss suspeshion parts, nismo power brace, sequential shifter, nismo slave/hardline, apexi boost gauge, new oil feed lines to turbos with restrictors. I have an apexi decs tac, assortment of auto meter guages,
I want to move my engine 3/4 inces back on the monts so it gets better balance and so I can fit my oil pump in there better (Will be loads of work), make the inproved hot pipe for the intercooler, This will all happen this winter. I will get it running on stock ecu and injectors and break in the engine. Then I will have enouf $ by then to start buying all the parts listed above till it is a screaming 600hp beast at hopefully 18psi. I still have allot of long hours ahead of me at work to afford all the parts that I need. I guess it is a life long project for me. I always finding more parts that I want for it to add to the ever growing list. I dont feel like typing any more and I am shure i missed some I will try to add them some time.
Carl H
gt30r eh?what influenced your decision and what are the specs that you got?ive got a 30r on my 20 right now and ive mixed feelings about it.......
rbsileighty
Sounds like you should fix you're problem with some TOMEI 82mm pistons Carl... easy fix
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Waiting on the freaking insurance company's body shop to figure out what is going to happen to my S13. Done so far before I got hit
Rips Intake ManifoldGriffen FMIC and piping3" downpipe- to Greddy PE2 exhaustbigger pump with stock regulator lolAP PFC for the RB20 (if someone dosen't want to wait 3-4 weeks to get one buy mine)EVC 4 boost controller
Whats going to happen if I have to get another S13 or after they fix the body? SC61 !!! yea yea about time it goes on HK$ manifoldHead Gasket Water pump and some other stuffCams prob Apexi 270's or maybe a mix of 260/270 or 270/280 who knows660cc Denso injectors and Maybe an AEM if I can get my PFC sold if not just going to Datalogit the PFC
Carl H
not really due to the rb20's small size but i think its more due in part to untuned cams/exh leak/possible charge piping leak.i will try to dyno the car soon but the turbo is pretty insane on a rb20 if you dont mind a bit of lag and shifting at 8.
rbsileighty
Cool... when do you see boost... and when do you see full boost?
Mind listing out what all you are running?
Carl H
well heres the current mod list:hcr32 rb20det s2 enginetomei 260/8.8 cams in/exhgreddy adjustable pullies in/exhgarrett gt30r .63 exh arhks exh manifold and hks gate with 14 psi springrips custom intake mani (1st USA one w00t!)rc 550cc 7mgte injectorsspearco core fmichks race bov (sounds like a duck)greddy emanage and e-01 profecz32 maf (blowthru is awesome!)chipped ecu (tuned for z32 maf and 550cc injectors and other little bits )tomei overkill r32 gtr fuel pump (its louder than my car is)
right now i start to see boost round 3k-ish but dont see a proper full boost, which is why i think i have some intake leaks and exhaust leaks.its fairly safe to say that i see useable "good" boost round 4.5k or so and it pulls like a cut bastard to redline (currently set at 8.5k).i plan on boost testing the system again to see what i can find leak wise and if that turns out to be inconclusive then look at other potential problems.i want to dial in the cams a bit to see if they will improve spool time which is one of the main reasons i got them, but they do fix the 6.3k drop off that most rb20's ive seen have.
rbsileighty
Might want to back the rev lim down to 8250 since I've heard that's the limit of the stock valvetrain from some aussie guys.
Other than that... sounds like a sweet setup bud! Go put her on the rollers!
How's the fitment of that HKS manifold and wastegate in there... tight or fits fine?
eh?
AEM EMS, 5 bar map sensorT3/t4 50 trim 17psi, turbonetics 62-1/t3 waitingRoss pistons, ringsPolished rods, ARP boltsGreddy IMQ45 TBARP Head studsNismo LSD
Engine misfires @5500 rpm, tryng to get new coils
krayton
eh? wrote:AEM EMS, 5 bar map sensorT3/t4 50 trim 17psi, turbonetics 62-1/t3 waitingRoss pistons, ringsPolished rods, ARP boltsGreddy IMQ45 TBARP Head studsNismo LSD
how you liking the ems? i still gotta get my tuned. you get that problem taken care of?
eh?
I wish I never bought it. The problem is still there, I think it's due to the ems poor ability to read the cas. The problem is wide spread through out the ems community. If my stock ecu and pfc can read the cas fine, and there are zero cases of the problem with other links, haltech, wolf 3d's then it's their fault.
krayton
thats awful to hear.
email me at [email protected] if you can with more details. id really like to know whats going on
Carl H
lol, no redline is set at 8.5 but i usualy shift at 7.5k to be safe.the hks manifold fits pretty damn well, much much better than the stock one could ever hope to be.wastegate comes really close to the brake lines so brake fluid tends to get a bit toasty............proly will make some sheilding and custom lines to fix that problem.
rbsileighty
You've got me curious bud... post some pics Carl!
SillyRB
RB25DETMicrotech LT-12Microtech Dash UnitXS Enginnering Power PackRPS 6-Puck ClutchJ30 Limited Slip Differential (LSD)Custom SOLID MOTOR MOUNTSMines Short ShifterGreddy Boost Controller (Profec B II)A1000 Aermotive External Fuel Pump1000 cc InjectorsAeromotive Fuel FilterStainless Steal -8 FeedStainless Steal -6 Return1.2mm Greddy Head GasketARP Head Studs (12pt)New Nissan Water PumpNew Nissan Oil PumpPower Enterprise Timing BeltQ45 Throttle BodyGreddy Intake Manifold HKS Exhaust Manifold HKS 40mm Wastegate (Custom Dump) PT 67 Turbo .81 Back P-TrimPrecision FMIC (31.5 x 10.3 x 3.5)TIAL Blow Off ValveA few other things i can't remember..............(Or dont feel like listing)
Right Now on a Mustang Dyno making about 440 RWHP...on low boost cant run more than 19 psi without a mis-fire. I need Coils. Soon going to Bosch coils.
SillyRB
I am running into a similar problems with the coils. Except mine mis-fire with anything over 19 psi . I am going to Bosch coils / and custom wires in the next few weeks. I think the OEM coils with the resistors and internal igniters have problesm working with StandAlone EMS's.
krayton
^ you guys with problems with the ignitiers. assuming your series 2 then?
SillyRB
krayton wrote:^ you guys with problems with the ignitiers. assuming your series 2 then?
Yes, so with my Computer i need to figure out a way to run an igniter chip w/ the microtech harness and the Bosch coils.
eh?
It's a series 2 but the coil misfire issue affects all Nissan DIS BTW: Have you started using your EMS yet? Check out what the aem rep said as well as the other poster. $1600 pos
DETurbine
Car: Nissan S13 RB25
RB25DETWiseco 86.5mm pistonsRB26DETT rodsARP head studsARP rod boltsARP mains1.2mm head gasketACL rod and main bearings
Precision SC61 76trim .63a/r 38mm TialMegaSquirt stand aloneACT 6puckFMIC800cc injectorsJGY fuel railNismo FPR
R200 VLSDAGX w/sportline springsKosei K1's w/ Nitto 555's (245's) & some MT drags for the strip.GTspec exhuast3inch downpipeetc.......Should have around 500-550hp by this summer and shooting for higher next spring.
krayton
eh? wrote:It's a series 2 but the coil misfire issue affects all Nissan DIS BTW: Have you started using your EMS yet? Check out what the aem rep said as well as the other poster. $1600 pos
im keeping my eye on it. ive started, but havent driven or tuned yet. i need to switch to series 1 ign.
just gotta install the wideband, then im hoping to not have this problem. s14drift has called them, id say do the same. kamin says aem has a real good tech support.
keep me updated
