RB Lower Shifter Bushing, Just Broke, WTF! were out driving, and my friend want,
FinkenS14
Car: 1995 Nissan 240sx S14
So me and my friend were out cruising and I let him drive my car. Totally trust the guy, totally legit, knows his s***.
First dig my friend went WOT, threw second, and all sudden the shifter got STUPID stiff. Like you really had to push and pull on it to get it to go into gear. But it eventually loosened up within a few miles of driving.
Second run, Well we go from a stop light, get into it, he throws second, and then throws third, and all sudden the shifter is acting like it did when I got my motor set, totally rotating around in the transmission. Great, WTF
BRAND NEW BUSHING from Nissan. The plastic one that goes on the end of the stick
Part # 32861-01G00 (that is correct, right)
ANother thing, the snap ring that holds the shifter down came off too!!! WTF! So we messed with it, and got it into third and limped it home.
Is this normal for the bushing to take a s*** like this? Maybe a total of 141 miles on the new bushing, and caput. How f***in gay.
So the Nissan dealers are closed tomorrow, the plastic one is nowhere to be found in the shift hole. Is there anything that I can put onto the end of the shifter to make it work again, and maybe something permanent?
Thanks for any help guys
-Finken
Modified by FinkenS14 at 2:11 AM 8/23/2009
Modified by FinkenS14 at 2:24 AM 8/23/2009
FinkenS14
Just got some advice that if the snap ring is bad/loose itll f*** the bushing real quick?
In this case my snap ring has always been kinda loose, and the shifter has always moved up and down in the hole about an 1/8th inch or maybe a tiny less
Also is there any way I can get the bushing from Napa tomorrow? Like what wud I tell them the bushing came out of?
FinkenS14
Nobody?
Bluefire
I've never seen someone smash that plastic bushing. The shifter should move up and down an 1/8"- 1/4". There is a sort metal spring under the plastic bucket that allows for this movement. Are you buy chance using a short shifter? I have also seen some aftermarket brash bushings, but have no idea where to get them..
mrflip69
I've seen the brass bushings from either Enjuku or Phase2. Hell, maybe even frsport, but that's for the KA shifter--so not sure if that would transfer to an RB shifter.
