rb/ka transmission a success.
unstable240
Car: OG RB20DET
I know for a fact that the KA trannie will bolt up to the RB20DET without switching the bellhousing. I have done it twice now on a RB20DET and RB20DET AWD. The shifter does sit further back roughly 1-1.5". On a regular RB20 there are only 2 bolts that don't match up which was fine with me. On the AWD version 4 bolts don't line up which can cause problems...
klh6686
Car: '92 FB stock daily
'90 FB w/ RB20
'92 FB w/ VH45
well since my transmission decided today that i no longer need 3rd, 4th, and 5th and that 1st and 2nd and sometimes reverse are sufficient enough. So it looks like this weekend i will be taking the rb20's transmission and comparing it w/ the sohc and figuring out how to get 6 gears back.... wish me luck
OKCA18DET
yes please do a more detailed discription if you do this and get it to work...
themadscientist
unstable240 wrote:I know for a fact that the KA trannie will bolt up to the RB20DET without switching the bellhousing. I have done it twice now on a RB20DET and RB20DET AWD. The shifter does sit further back roughly 1-1.5". On a regular RB20 there are only 2 bolts that don't match up which was fine with me. On the AWD version 4 bolts don't line up which can cause problems...
wait a minute, are you saying that the bellhousing to engine bolt pattern and starter placement on the KA and RB bellhousings are the same?
Karma240
in reply to wulfgangs somewhat obtuse observation of this forum I would be happy to clear up these issues. so hear goes
1st. I have the ka transmission on my rb20det with no frame or floor pan mods.
2nd. This does require a custom drive shaft unless you use the s14 drive shaft in which case it will fit but will also put undo pressure on your transmission and can cause premature wear on certain bearings.
3rd. The internals are almost exactly the same and swapable from housing to housing. the only real difference is the input shaft especially the bearings. (they are not as strong on the KA)
4th. I personally have done this swap and do not think it is worth the time or hassle.
So there ya go Do what you will with it.
Karma
unstable240
Car: OG RB20DET
I will take some pics this week since I have to get under there and show you how it looks...
swwifty
I was about to say, I knew I had heard that the KA transmission and the RB worked together before! ;-)
unstable240
Car: OG RB20DET
From me...
OKCA18DET
where's the pix
swwifty
yup yup.
unstable240
Car: OG RB20DET
OKCA18DET wrote:where's the pix
Well down here in GA it is raining like cats and dogs and I can't take the pics now or for the past week.... I will get them don't worry....
swwifty
stupid hurricanes!
OKCA18DET
unstable240 wrote:Well down here in GA it is raining like cats and dogs and I can't take the pics now or for the past week.... I will get them don't worry....
oh yea the hurricane
a 1g terror
Car: 1g dsm 12,9
OKCA18DET wrote:oh yea the hurricane
SO did his car get washed away? its been like 9 months and no pix..
gtrperformance
Car: FULLY BUILT 1989 USDM KPS13 W/RB20DET
No update on this? I'm about to attempt this swap tommorrow. Wish me luck.
drivnovrdaedge
Car: 1969 datsun 510
i am tempted to do this also
any updates from anybody
and where are you guys getting rb20 tranmission? .. i am having a hard time finding them
gtrperformance
JGY Customs has transmissions.
qu0vad1s
Car: Nissan 240SX LE 1995
I know i'm bumping a freakin' old thread, but I got to play with both transmission to rebuild mine.
Have a look here
http://www.rbforums.org/phpBB3/viewtopic.php?f=3&t=266
supersayianjim
Car: 89 240sx(s13)
bump on this thread for new discoveries???
dvrx7
Car: 1987 Rx7 Fc with an RB20DET
This is somewhat off topic but what slip yoke will fit with the rb20 transmission? Other than the obvious rb20 slip yoke, will the ka or sr20 fit?
Lopin18
Car: '89 Nissan 240SX Hatch KA24E
Just to share, after testing and moving away from a 240sx KA24e project, i got a RB25 Neo from a Stagea, this is what i found after testing the parts:
- KA Flywheel bolted into the RB25, hence the clutch i was using and pressure plate should work.
- KA Bellhousing bolted in 5 bolts (2 on the bottom had to be drilled, all the ones on the Starter side didnt fit) So i only have 5 bolts grabbing it.
- RB engine doesnt have a Starter mounting point, so i tested it and i plan to use 2 ring spacers to bolt it against the transmission, it should work.
Still havent put the transmission on it, just the bellhousing, but as it looks, its going to work.
