RB/KA temp sensor... can anyone help
gbaz77
Car: 240sx
ok guys i made a stupid mistake i think.
instead of changing the KA temp sensor with the one wire to the RB, i changed the KA temp sensor with 2 wires to the RB. just a few minutes ago while i was searching for info on here, i found a thread saying you should only change the temp sensor with 1 wire (zerothread?id=103069)
how bad is that? do i need to change it back??
and also, will the gauges on my KA cluster not work if the ground wires are not yet grounded??
thanks in advance for any help ,
gamay
gbaz77
Car: 240sx
bump
Carl H
doesnt matter, the engine coolant temp sensors read the same for both engines, however the gauge one doesnt.
