RB Intake Manifold
IslandBoy
Car: Datsun 260c, C33 Laurel, A31 Cefiro
I would like to change my RB intake manifold so I can put the trottle body to the front so I can use a front mount intercooler and the piping would be alot easier. Can I use a RB26DEt Intake Manifold on my RB20DET? What would I have to do as per procedure wise? Gasket, TPS, ETC, Injector rail ????? Would be a sipmle cahnge or are there alot of modifications to the manifold? Thanks
MidWest240Collector
I'm pretty sure the RB26DETT has an ITB setup and I'm sure it would require a lot of modification if it is possible.
krayton
found this for u 20 guys:
not sure on details. just cruising skyline pics.
ps. its usually easier to just run over the top piping as to changing to a non over the top manifold. (not saying its better, but your looking for easier). also try top hat?
MidWest240Collector
That is teh uber greatness. I want one.
300Plus
Car: 1995 S14 w/ Rb25det Series II
Is it me or does that pic look photoshopped? I bet that design would lean out your first cylinder. and it would def be easier to make a whole top section.
masticatingcow
Car: 94 Mazda FD3S
There's a guy on the skylinesdownunder.com.au forums who put the RB26 mani on his 20... and was very clear that it was a total bish to make work; something like 2 hours install, 6 hours fab time, or something ridiculous like that. Tophat makes an upper plenum replacement for somewhere around $400, and there's the RIPS manifold for around $1200.
I say, if you've got a RB26 manifold, lots of experience and LOTS of time, go with that. If nothing else, you can play on the wow factor. If you need to run a front mount on the cheap, go with Tophat. If you want to have the cleanest freakin' intake mani available for the RB20, get the RIPS piece.
Of course, you could just run the cold pipe in front of the motor to the cold side of a front mount. Even though the cold pipe will be running right next to the hot pipe, you'll still see some gains from the front mount.
lucky7
Car: 97 RB25 S14
looks like a VW manifold. weird.
krayton
300Plus wrote:Is it me or does that pic look photoshopped? I bet that design would lean out your first cylinder. and it would def be easier to make a whole top section.
i think its real
another angle
RB20DETodd
Car: 92 Nissan S13 coupe SE RB20DET
http://cgi.ebay.com/ebaymotors...QrdZ1
YOU HAVENT GOT MUCH TIME!!!!!!!!!!
RB20DETodd
And having the stock manifold is not hard just have to cut a little hood bracing and a 90 degree bend its easy.
masticatingcow
Car: 94 Mazda FD3S
That eBay mani looks like the Tophat upper plenum being sold with the stock lower runners.
