The Japanese 200ZR versions came with them.84datsun300zxTurbo wrote:Will any RB series engine fit in a z31
Has any one here ever done this swap? (if it can be done)
I wonder if ZR oil pan and mounts are still availible as OEM parts in japan (not nessecarily from nissan, but any OEM-style parts maker).evildky wrote:just to clarify the 200ZR in japan came with the RB20DET, any of the RB motors will bolt into a Z31 using the ZR pan and mounts, I am not sure which crossmember is required I'd guess it's the same as the turbo Z31 and yeah a few have been done tha I know of mostly the RB25DET
That's BS. It can easily be made to fit. It won't fit with the stock down pipes, but anything is possible with time and money.Dramier wrote:RB26 won't fit in a LHD z31 because of the steering components.
That car and the one next to it look familiarAZ-ZBum wrote:Why not go all out? RB26DETT the sucker.
The stock VG30ET will handle at least as much power as you'll ever get out of an RB25. And cost less. And have rebuild parts readily available.
Why someone would spend $2000 on a motor and all the time to swap it in and have it be slower than stock is beyond me.
Too bad they kept the clutch fanboileralum00 wrote:And, apparently those silly Japanese will shoehorn an RB26DETT anywhere it'll fit:
If it is like the clutch fan on my Z32TT, it flows like 6500 CFM. Good luck finding an electric fan that will flow anything near that.81na ZX wrote:Too bad they kept the clutch fan
Theres also a thai s130 with a RB26 in it thats been around for a while
I don't know if theres any US s130's like that. s30's are another thing all together
yeah, because their 30 year old stock fans flow less than a modern electric fan81na ZX wrote:pah, cooling's overrated Its about the parasidic drag
j/k - most s30 guys go electric fan right out of the box though
actually most of us s30 guys keep the stock mech fan, because there just isn't much room between the engine and the rad for most elecfans, even the thinnest fans have to offset to clear the waterpump puley, no most s30 turbo guys go electric because if you wanna run an I/C you kinda have to get the mech fan out of the way for piping, personally I just can't get behind the idea of a pusher fan so I got a pair of small thin twins, they barely do the trick, but I am running an aftermarket thermostat and need to replace it with an OE as the opening in the OE's are larger and flows better81na ZX wrote:pah, cooling's overrated Its about the parasidic drag
